justinyeskey
May 24, 2021Aspirant
C6300 – Unable to login into Modem
Although my C6300 – AC1750 WiFi Cable Modem Router is working and my connection speed is great I'm unable to login to my modem's menu/settings page. I have tried http://routerlogin.net which just rou...
May 24, 2021Guru - Experienced User
Try a different browser.
Also try going to 192.168.100.1
justinyeskey
Thanks for your help. Unfortunately I just tried and neither of those suggestions worked.
- plemansMay 24, 2021Guru - Experienced User
What error are you getting?
whats actually happening when you do that?
have you tried hardwired into the router?
- justinyeskeyMay 24, 2021Aspirant
Yes I am hardwired to my router. See screenshots of the error message I am getting.
Noticed that my screenshots aren't showing. Please see attached for the error message.
