Net_Gear_Man
Apr 12, 2020Initiate
C6300 and NordVPN
Hello, I'm inexpert enough not to know exaclty whyic "Model" to enter into the imperative field (I just think of me as having a C6300) WiFi router I picked up new in Dec '16. I use NordVPN on...
- Apr 13, 2020
Net_Gear_Man wrote:
Why don't I just quote the reply I got: "Please search for a setting called "VPN passthrough" or "IPsec passthrogh" and enable it if it is present. Also, try disabling IPv6, disabling DDNS and also try lowering the setting of the router's firewall." So drawing on my vast inexpertness, I thought I pass this bit of wishful thinking to to this board in hope someone out there knows what they're talking about and can help with steps to take.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Search for the prompts there.If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
michaelkenward
Apr 13, 2020Guru - Experienced User
Support | NETGEAR
