Squ1gly
Sep 15, 2020Initiate
C6300 Cannot access routerlogin.net
Hello. When I try accessing routerlogin.net I get "This page isn't working right now". I've tried using 192.168.0.1 and 192.168.1.1 with the same response. I tried using both Chrome and Edge. I've tried using my PC and my phone. I've tried factory resetting my router. Nothing has worked. Is there any known fix?
Thank you.
- Thank you! The Firefox suggestion worked!
Does your internet work?
What are the led's on the router doing?
Have you tried accessing it via 192.168.100.1?
Also, try firefox. I've seen users have luck with firefox when the others didn't work.
- Squ1glyInitiateThank you! The Firefox suggestion worked!
Glad to hear you got it working!
If you mark it solved, it may help the next person with this issue.
