tklahn79
Jan 24, 2022Aspirant
C6300 No wifi
So I'm use to having to periodically restart my router for some reason. But now, as pictured, the wifi is not working. My wired devices are fine, but all the others aren't. I'm not sure what the light...
Jan 24, 2022Guru - Experienced User
Your lights are telling you there's issue with the upstream. Which is should impact both wired and wireless devices.
Do you have screen snip of your cable connections page and your event logs?
- tklahn79Jan 25, 2022Aspirant
- wcalifasJan 25, 2022Prodigy
Did you try a hard reset? press the reset pinhole for about 30 seconds with a paper clip. It will go back to factory default in case you have certain settings that you made such as wifi ssid or changed the password for the wifi.
