tklahn79
Jan 24, 2022Aspirant
C6300 No wifi
So I'm use to having to periodically restart my router for some reason. But now, as pictured, the wifi is not working. My wired devices are fine, but all the others aren't. I'm not sure what the light...
Jan 24, 2022Guru - Experienced User
Your lights are telling you there's issue with the upstream. Which is should impact both wired and wireless devices.
Do you have screen snip of your cable connections page and your event logs?
