scoale's avatar
scoale
C6300 router, would like to add wnr2000 as a repeater.
I can't find on the menus how to add the netgear wnr2000 as a repeater, is it possible?
  • ElaineM's avatar
    Mar 02, 2017
    Welcome to the community, scoale
    Your devices should have a feature that's called "Wireless Repeating".
    If you do not have that option, there's no way to do it. The only way to extend the signal is to use a cable between these 2 devices.
