cuse165
Apr 01, 2021Aspirant
C63000 modem/routrer
I am using a modem router combo and I wanted to know if you can turn off the router part and just use it as a modem. Model Number C6300.
1 Reply
This guide goes over how to do it: How to set the cable modem/router to be on modem only | Answer | NETGEAR Support
the manual also has it.
