DW123456
Aug 31, 2020Tutor
C6300v2 not emitting WiFi signal
Hi all, For no apparent reason my router/modem has stopped emitting it's WiFI signal. I've tried power cycling, rebooting and following the instructions if the inner 'radios' are on or off. Nothing ...
- Aug 31, 2020
Glad to hear it! if you mark it solved it can help the next person
Aug 31, 2020Guru - Experienced User
Did you try pushing the wifi on/off button for 2 seconds?
