ravensrulz
Mar 08, 2020Guide
C6300V2 stopped displaying 5ghz SSID when scanning my networks
My Netgear Modem/Router stopped broadcasting my 5GHZ WIFI connections, on Primary and Guest networks. I've tried checking my network card, I go into GENIE and they are still shown as there, nothing ...
- Mar 16, 2020
Mar 09, 2020Guru - Experienced User
What is the 5ghz led doing on the router?
If you log into the router (not through genie) but through the browser, what is it showing for the 5ghz network? is it enabled, what channel broadcasting on, what's all going on for it?
what firmware is on it?
is it running with a seperate ssid from the 2.4ghz?
ravensrulz
Mar 09, 2020Guide
Hi,
I was able to resolve the issue, but don't want to keep going through it. I actually went into the router login through my browser and went and erased my settings back to factory defaults, than created the wireless SSID's over again and the are now showing up. I am wondering if the latest XFinity Firmware update may have had something to do with it. But as of now, I have it working again. Thank you for following up with me.
