ravensrulz
Mar 08, 2020Guide
C6300V2 stopped displaying 5ghz SSID when scanning my networks
My Netgear Modem/Router stopped broadcasting my 5GHZ WIFI connections, on Primary and Guest networks. I've tried checking my network card, I go into GENIE and they are still shown as there, nothing ...
- Mar 16, 2020
ravensrulz
Mar 16, 2020Guide
Its a Dell Inspiron 620 Windows 10 X64 OS.
I mean, its a great PC, just needs some modifications.
Mar 16, 2020Guru - Experienced User
is the wireless card installed in the pci slot?
Is it using an adapter?
What pci slot do you have available? x1,x4,x16?
Because they make adapters that you can upgrade to even an AX device if you have the appropriate open pci slot.
