ravensrulz
Mar 08, 2020Guide
C6300V2 stopped displaying 5ghz SSID when scanning my networks
My Netgear Modem/Router stopped broadcasting my 5GHZ WIFI connections, on Primary and Guest networks. I've tried checking my network card, I go into GENIE and they are still shown as there, nothing ...
- Mar 16, 2020
Mar 16, 2020Guru - Experienced User
is the wireless card installed in the pci slot?
Is it using an adapter?
What pci slot do you have available? x1,x4,x16?
Because they make adapters that you can upgrade to even an AX device if you have the appropriate open pci slot.
- ravensrulzMar 17, 2020Guide
This doesn't mention PCIe, whould this work?
- plemansMar 17, 2020Guru - Experienced User
it would depend on your computer.
but the other one is an AX card and can be upgraded with a different m.2 wireless card out if you wanted to upgrade in the future. Its basically a m.2-pci adapter card with an included intel ax200 card.
I just ordered the one you provided, am a Prime Member so got a little discount and faster shipping.
Now, I have another questions for you, I have to constantly reboot my AC1750 Cable Modem/Router/WiFi because I loose my speeds, until I reboot it. I have checked the signal strength coming in and it appears normal, is this device suseptable to dropping Signal? Even when I am directly connected via Ethernet cable to the back. Is there something I can do to make sure that my Internet speed stops dropping in and out throughout the day, I am on 350mbps and it will go down to 15 downstream and 2-3 upstream. Is it the router? I've even swapped out coaxes.
Do you have a screen snip of your modem connections page?
usually if both wired and wireless drop speeds, it tends to be the connection back to the isp.
Thats what I suspect, I've called them in the past, of course, I get the answer of we aren't seeing anything on our end, so I am going to call and have a technician come out and take a look.
And both wifi and direct connect drop off.
you can take a screen snip of the modem connections page. It shows the connection back to the isp in a snap shot. that can help us tell if that could be an issue.
ok, now this is really really strange, its says my downstream is not connected to the cable.
try and get all the upload/download channels for me to view.
You need all the data. error/uncorrectables/etc. that info is important too
where would I find that part?
you scroll to the right of the snr.
make sure to include all the download channels. scroll down. your cropping stuff out.
Now that connection is back.
Mar 17 2020 09:10:07 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 16 2020 15:11:58 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 16 2020 07:21:51 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Warning (5) ToD request sent - No Response received Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 15 2020 15:49:32 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 15 2020 06:13:44 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 14 2020 02:53:27 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 13 2020 12:46:26 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 13 2020 05:08:46 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 12 2020 09:35:05 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 11 2020 12:37:55 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 11 2020 02:37:54 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 10 2020 17:54:12 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 09 2020 16:10:54 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Mar 09 2020 09:30:07 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 - ravensrulzMar 17, 2020Guide
this is all I could find.
Here's what you can do.
1. factory reset and re-install the combo device.
2. have the isp inspect the line. you're specs don't look bad but it doesn't mean its not something after the hub.
3. try a different modem/router. Potentially it could be the combo device.
- ravensrulzMar 19, 2020Guide
Hi Plemans, the new Wireless NIC arrived today, all installed, very easily, the one you suggested, works great, although, I had to go into device manage and advanced on the card to get my correct 802.11 settings correct and when I did that, I blew away my network, lololol. Nothing was showing up for available networks, so, I uninstalled the device from device manager, reinstalled the drivers from Intel, recreated my Wireless Network, and now can put my PC on 5GHZ which is showing now. Also, had Comcast Technician come over yesterday, he checked the signal directly into the c6300v2 1750AC, signal strength was strong, so, the dropping of my speed and having to reboot my modem/router every time, to get my speed back, he believes is tied to the Node being house out on the pole somewhere, thinks one of the Link Switches may be having issues, and I asked my neighbor, she has the same problem, so he was putting request in for Watchtower Monitoring to find out, where exactly from Node to panel switches are broken, maybe a fuse on the switch, not sure, so hopefully will know more soon. I wanted to hook up the Bluetooth connection that came with the card, but don't have an additional usb pin plug to put into, my USB ports are hard wired into the circuit board it looks like, but thats okay, I am using a Bluetooth External USB PNP that works just fine. I want to thank you for all the outstanding help you have provided me, many KUDOS to you my new friend!!!! Jeff.
- plemansMar 20, 2020Guru - Experienced User
glad to hear you got it working great!
You do want to get the intel drivers directly from intel. windows update doesn't pick up the most recent and its been changing fast with the AX cards.
