ravensrulz
Mar 08, 2020Guide
C6300V2 stopped displaying 5ghz SSID when scanning my networks
My Netgear Modem/Router stopped broadcasting my 5GHZ WIFI connections, on Primary and Guest networks. I've tried checking my network card, I go into GENIE and they are still shown as there, nothing ...
- Mar 16, 2020
Mar 16, 2020Guru - Experienced User
ravensrulz
Mar 17, 2020Guide
This doesn't mention PCIe, whould this work?
- plemansMar 17, 2020Guru - Experienced User
it would depend on your computer.
but the other one is an AX card and can be upgraded with a different m.2 wireless card out if you wanted to upgrade in the future. Its basically a m.2-pci adapter card with an included intel ax200 card.
