pat5150
Jan 31, 2020Aspirant
c6300v2 Stuck on amber internet light
Firmware: 1.0.3.8_1.0.60 Nothing changed, then all of the sudden, the connectivity light went from green to amber. The router will not detect the internet signal. If I hardwire from the modem (Net...
- Feb 01, 2020
The firmware update, plus a new signal from Comcast to the router fixed the problem. Back to green. Not sure why it went out anyway.
Good job, Pat!Thanks, Pat!
pat5150
Yes, I power cycled. Did the reset. Power cycled the modem and computers. Called Comcast and they said since I have internet, the modem is working fine and the router is the problem (duh).
- pat5150Jan 31, 2020Aspirant
Just upgraded the firmware to
Firmware Version
V1.0.4.36_10.0.93
Power cycled, and still Amber- pat5150Feb 01, 2020Aspirant
