pat5150's avatar
pat5150
c6300v2 Stuck on amber internet light
Firmware: 1.0.3.8_1.0.60 Nothing changed, then all of the sudden, the connectivity light went from green to amber. The router will not detect the internet signal. If I hardwire from the modem (Net...
  • pat5150's avatar
    pat5150
    Feb 01, 2020
    The firmware update, plus a new signal from Comcast to the router fixed the problem. Back to green. Not sure why it went out anyway.
    Good job, Pat!
    Thanks, Pat!
