1bobert
Oct 28, 2020Aspirant
C6900 - Ethernet 600 Mbps, 5 GHZ 150 Mbps, 2.4 GHZ <40 Mbps
Testing internet speeds with ethernet connected computer and phone for wi-fi < 5 feet away from router. Is the drop off from wired to wireless normal? Was in auto and went into manual and toggled cha...
Oct 29, 2020Guru - Experienced User
do you have the C6900 or C7000?
Wired will be much faster than wireless. It has less interference, less overhead, and won't drop off with distance.
As well as certain device's wireless is going to be different. a 1x1 antenna is going to have lower speed than a 2x2 antenna.
And 2.4ghz is much much slower than 5ghz which is slower than wired.
Also, even through 5ghz is much faster than 2.4ghz, it doesn't penetrate as well or broadcast as far.
So there's many factors.
What speeds do you get wired?
What speeds do you get 2.4ghz?
And 5ghz?
What site are you testing on and what device?
- 1bobertOct 29, 2020Aspirant
See title.
Ethernet 600 Mbps
5 GHZ 150 Mbps
2.4 GHZ <40 Mbps
C6900.
Using Google Internet Speed Test on a Oneplus 5t.
- plemansOct 29, 2020Guru - Experienced User
have you tested any other devices?
the 2.4ghz is usually what you can expect.
same as you're hitting full speed on wired.
So its a question of the 5ghz.
What link speed do you have (not the same as throughput)
