1bobert
Oct 28, 2020Aspirant
C6900 - Ethernet 600 Mbps, 5 GHZ 150 Mbps, 2.4 GHZ <40 Mbps
Testing internet speeds with ethernet connected computer and phone for wi-fi < 5 feet away from router. Is the drop off from wired to wireless normal? Was in auto and went into manual and toggled cha...
1bobert
Oct 29, 2020Aspirant
See title.
Ethernet 600 Mbps
5 GHZ 150 Mbps
2.4 GHZ <40 Mbps
C6900.
Using Google Internet Speed Test on a Oneplus 5t.
Oct 29, 2020Guru - Experienced User
have you tested any other devices?
the 2.4ghz is usually what you can expect.
same as you're hitting full speed on wired.
So its a question of the 5ghz.
What link speed do you have (not the same as throughput)
