vikasG
Jan 30, 2021Aspirant
C7000-100NAS ethernet works but no wifi
This was working fine for 2 years. Suddenly the Wifi on both 2.4 and 5 GB STOPPED showing up on my devices. However, the ethernet is working fine. Everything shows Good on the router.login. Please he...
antinode
Jan 30, 2021Guru
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Pay particular attention to the
"WiFi On/Off button with LED". Did you press it? Further reading might
not hurt, either.
- vikasGJan 30, 2021Aspirant
Did all of that and had no luck. Hence I raised it here. When I go in through Netgear gini or the laptop to connect to the router, the wifi shows everything is good and green. Very confusing
