Diemerson's avatar
Diemerson
Follower
Mar 18, 2020
Cable modem CG3000D
I have the cable modem CG3000D, his wifi says it is N technology, but it is not more than 35 mega in WiFi, what procedure to solve? Thank you very much in advance
  • plemans's avatar
    Mar 18, 2020
    N300 is 2.4ghz based. 2.4ghz is inherently slower than 5ghz and its even made worse in congested environments.
    procedure to get more speed? add in an router/access point that supports 5ghz or upgrade the router to wireless AC/AX.
