marmaladestripe
Apr 29, 2021Tutor
Can’t log in to routerlogin.net for Trek N300 PR2000
Hi all! I have a Netgear Trek N300 PR2000 that I’m trying to use as a range extender in my 240ish year old house. My main modem/router is a Motorola Surfboard 6782. I’m trying to log in to the T...
Apr 29, 2021Guru
Did you log into your primary router and find the IP address the primary router assigned to the trek?
- marmaladestripeMay 02, 2021Tutor
I did log in to my main router, but it's not showing the Trek as one of the devices connected to it. I have the MAC address for the Trek, and it's not listed. I did press the reset button on the Trek, so it's possible it got disconnected from Extender Mode for my main router. But now I can't log into it to set it back up. Ideas?
Edit: Wait, found it! I was able to use Netgear Genie on my MacBook to find the IP. Updating firmware on the Trek and going from there.
