JoannieGetsHelp
Nov 08, 2023Aspirant
Can’t login to WNDR4300 connected to AX20
I had my N750/WNDR4300 router connected in AP mode to my TP Link AX20 last year. AX20 failed and was replaced. I’ve reset the WNRD4300 and am trying to log in to set AP mode again. I can co...
JoannieGetsHelp
Ok. I still can't login to get to change it to AP mode.
I directly wired the WNDR4300 to my iMac (the only machine in the house with an Ethernet port). I then connected to the NetGear06 wifi on the iMac. I cleared browser history on Safari and tried routerlogin.net, routerlogin.com, 192.168.1.1, and 192.168.1.2 and they all failed to load.
When the WNDR4300 was connected to the AX20, I was able to see the device was assigned 192.168.0.213. That also doesn't work.
I shut the wifi off on the iMac to be sure it's only looking at the hard-wired router, and looked up the comparable ipconfig command ifconfig, and found IPv4 address 169.254.139.247 and that didn't work either!
Thanks for sticking with me!
michaelkenward
Nov 08, 2023Guru - Experienced User
You can't mess around with IP addresses willy nilly. You have listed set of addresses that can't talk to each other.
By default, Netgear routers set themselves to 192.168.1.1. Everything else on the network uses 192.168.1.###.
Your WNDR4300 router will opt for this one by default.
Modem routers go for 192.168.0.1 and 192.168.0.###.
These can't talk to each other.
I have no idea where 169.254.139.247 comes from.
Another problem is that you can't just plug things in an out. You have to restart devices in the correct order so that the later arrivals can see what is upstream and adapt themselves accordingly.
NetGear06 is usually the default SSID of a router. If you can connect to it, then whatever does the connecting may also be able to tell you the IP address of the connection.
The 192.168.0.213 is the one that the AX20 allocated to the WNDR4300. If the two aren't connected, then the WNDR4300 won't get that address.
That address suggests that the AX20 is working through 192.168.0.1. Is this a modem/router or gateway? Maybe that's what TP-Link uses for routers.
Did you reset the WNDR4300 before you tried connecting to it?
Then connect it to the Mac. Keep wifi out of it. Turn it off. That just confuses things as it tries to get an IP address from the .TP-Link.
Dis you read this?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
