DanKe
Jun 23, 2016Aspirant
Can AC1750 model R6400 be used with Apple's Time Machine?
Some models are listed as "Time Machine compatible." Not sure what that exactly means. Can this model be used with Time Machine?
Thanks!
Hi DanKe,
Yes, it can be used to setup Time Machine. You may refer to page 72 of the device user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi DanKe,
Dexter
Community Team
