Simando1995
Jun 10, 2023Aspirant
Can anyone help?
Hello I was wondering if anyone can help me solve this connection problem shown on my router? It's been like that for a couple months now since my internet provider updated the system . Cheers
Kitsap
Jun 10, 2023Master
Cheers
What is the brand name and model number of the modem or optical network terminal connected upstream of your R6020?
Have you powered down your upstream device and your router, then powered them up with the upstream device first and then your router a few minuter later?
Simando1995
Brand is Netgear nighthawk
Model R6020
& Yes I have
Model R6020
& Yes I have
- KitsapJun 10, 2023Master
Model R6020
& Yes I haveRepeat question: What is the brand name and model number of the modem or optical network terminal connected upstream of your R6020?
- Simando1995Jun 10, 2023AspirantNo idea sorry
Simando1995 wrote:
No idea sorryThe WAN input port of your R6020 has to be connected to some internet source with an Ethernet cable. Does the cable just plug in to the wall?
