belotkru's avatar
belotkru
Can DLNA see Readyshare folders?
Connected a HDD to my Netgear router. Readyshare is accessible. I created a folder through ftp connection as I'd like to add stuff remotely. My Samsung TV sees the DLNA server but no matter how many times I recan for media or restart the router I can never see the files or folders I created.
My assumption is DLNA does not see things placed one the drive unless they are placed through the dlna library which only allows local connections, am I correct on that?
I was hoping to be able to ftp media files directly into a folder that was accessible on Samsung TV directly.
1 Reply
  • FURRYe38's avatar
    What model router do you have?
    Check with the TV mfr on DLNA support and how to connect and see files.
    Test with a different device, i.e. PC or laptop.
