BatresAF
Sep 29, 2020Follower
Can I Add a LAN2 to BR500 Router
I know that in Router BR500 you can create another subnet with different IP Address from LAN1. I tried to add another subnet LAN2 assigned to a VLAN ID 3 which is a VLAN that has TAG port 3 of the router. The issue here it that when I Plug my computer to port 3 of the router it does not give access to the internet. Am I doing something wrong creating a subnet of what else can I do to have access to internet in the post with a new subnet.
1 Reply
- SquareJAspirant
Were you able to solve the problem? I am having the same issue. I bring up LAN2-4 but cannot ping their IPs with devices plugged in to a switch connected to that port or directly to the port on the BR200. It seems like the interface is not coming up.
