JaxDav_M
Jan 01, 2021Aspirant
Can I get WEP on my router?
I have set up my router and have internet and all, but I want to set up a WEP as my old nintendo DS wants a WEP so I can get some sweet pokemon from old events. Is there anyway to set up a wep or is ...
JaxDav_M
It is an AC1900 Smart Wifi Router, Model R7000
Jan 01, 2021Guru - Experienced User
wep was supersceded by wpa, and then that was by wpa2 and now wpa3.
Its unsecure. Not even close to secure.
If you need to get a device online you could enable the guest mode on the r7000 and leave it broadcasting on the open because that's basically what wep is doing.
- JaxDav_MJan 01, 2021Aspirant
Thank you, that worked!
