SlowBro
Nov 11, 2015Aspirant
Can I lower streaming video priority on a WNR1000v3?
Is there a setting I can make in my router to either decrease the priority of streaming video or increase the priority of my Citrix remote desktop connection? I use Citrix remote desktop to the o...
- Nov 12, 2015
There are no other settings you can adjust aside from using the QoS.
QoS will help you to prioritize which devices/application that needs more attention and that's the only thing it can do.
There is no specific setting in the router that lets you define how much speed should a specific device/application should have.
You may perhaps look into some 3rd party software that would let you configure the settings you require.
SlowBro
May need a DD-WRT or similar device to do this. I'm not interested in flashing my Netgear so probably I will stand up a small computer as a pfSense router then turn the Netgear into a switch/AP. That is, if upgrading Comcast to 25 Mbit doesn't do the job, which it may.
Here's what I see with two Netflix streams going, even at the lowest bandwidth:
Reply from 4.2.2.4: bytes=32 time=1498ms TTL=57
Reply from 4.2.2.4: bytes=32 time=1344ms TTL=57
Reply from 4.2.2.4: bytes=32 time=1264ms TTL=57
Reply from 4.2.2.4: bytes=32 time=1824ms TTL=57
Reply from 4.2.2.4: bytes=32 time=2075ms TTL=57
SlowBro
Although I'd still like to know if it's possible to do this within the router, the upgrade in speed fixed the problem. It was applied MUCH faster than I anticipated it would be applied. Kids are in the front room watching Netflix and here's my ping times now. AHHHHHHHHHHHHHHHH.
Reply from 4.2.2.4: bytes=32 time=71ms TTL=57
Reply from 4.2.2.4: bytes=32 time=32ms TTL=57
Reply from 4.2.2.4: bytes=32 time=52ms TTL=57
Reply from 4.2.2.4: bytes=32 time=29ms TTL=57
Reply from 4.2.2.4: bytes=32 time=34ms TTL=57
Reply from 4.2.2.4: bytes=32 time=30ms TTL=57
Reply from 4.2.2.4: bytes=32 time=42ms TTL=57
- ElaineMNov 12, 2015NETGEAR Employee Retired
- SlowBroNov 12, 2015Aspirant
And the QoS only adjusts the upstream. I'd said above I'll likely use third party software so it looks like that's my only choice.
- ElaineMNov 16, 2015NETGEAR Employee Retired
That's right. Best option for you is to look for a 3rd party software that can manage the settings you want.
