SlowBro
Nov 11, 2015Aspirant
Can I lower streaming video priority on a WNR1000v3?
Is there a setting I can make in my router to either decrease the priority of streaming video or increase the priority of my Citrix remote desktop connection? I use Citrix remote desktop to the o...
- Nov 12, 2015
There are no other settings you can adjust aside from using the QoS.
QoS will help you to prioritize which devices/application that needs more attention and that's the only thing it can do.
There is no specific setting in the router that lets you define how much speed should a specific device/application should have.
You may perhaps look into some 3rd party software that would let you configure the settings you require.
SlowBro
Although I'd still like to know if it's possible to do this within the router, the upgrade in speed fixed the problem. It was applied MUCH faster than I anticipated it would be applied. Kids are in the front room watching Netflix and here's my ping times now. AHHHHHHHHHHHHHHHH.
Reply from 4.2.2.4: bytes=32 time=71ms TTL=57
Reply from 4.2.2.4: bytes=32 time=32ms TTL=57
Reply from 4.2.2.4: bytes=32 time=52ms TTL=57
Reply from 4.2.2.4: bytes=32 time=29ms TTL=57
Reply from 4.2.2.4: bytes=32 time=34ms TTL=57
Reply from 4.2.2.4: bytes=32 time=30ms TTL=57
Reply from 4.2.2.4: bytes=32 time=42ms TTL=57
ElaineM
Nov 12, 2015NETGEAR Employee Retired
- SlowBroNov 12, 2015Aspirant
And the QoS only adjusts the upstream. I'd said above I'll likely use third party software so it looks like that's my only choice.
- ElaineMNov 16, 2015NETGEAR Employee Retired
That's right. Best option for you is to look for a 3rd party software that can manage the settings you want.
