Pablo777
Sep 13, 2021Tutor
Can I plug in my cat 5 from my R6850 to the Signal Range Extender?
I ordered a 2021 release - 1.2 Gigabit Dual Band Signal Range Booster, up to 3000sq.ft - 5 GHz/2.4 GHz, Network Repeater, 30+ Devices, Indoors/Outdoors, Easy One-Click Set Up, Ethernet Portand would ...
- Sep 16, 2021
I bought a new router R6850 AC2000 and installed it correctly. All works great now. The WIFI extender works great as well. I found out that the network port is for conneting to a computer if the computer doesn't have a wireless adapter. Thanks for your help.
michaelkenward
Sep 14, 2021Guru - Experienced User
Pablo777 wrote:
I can't find a model number ....
If Netgear made it, there is always a model number.
Pablo777
Sep 14, 2021Tutor
