SHamburg
Dec 11, 2020Tutor
Can I set up multiple channels with this modem? 5.0 and 2.4
I'm trying to install a Honeywell smart thermostat but found out it's not compatible with 5.0 Modem speeds, needs to be 2.5 (2.4?). Is there a way to set up this modem to have 2 channels ? I hav...
- Dec 11, 2020
The cm1000 is a modem only. It has no router or wireless capability.
What actual router do you have?
Dec 11, 2020Guru - Experienced User
