Elle01's avatar
Elle01
Tutor
Jan 28, 2022
Can I update firmware via webpage file upload from MacBook using WIFI instead of hardwired cable?
Hiya, Thanks to help here I've finally figured out how to upload a frimware update file that was refusing to do it's thing quoting Unknown Error 1 .. Despite the fact I am now able to do steps 2 - 7...
  • Elle01's avatar
    Jan 28, 2022
    Update..
    I started this question as a new topic thread - someone kindly answered it as part of a different question I posted. I can't see how to delete the above post so I will post the answer here incase it helps anyone else too...
    "You can do it over wifi.
    We recommend over wired because its a solid connection without interference.
    But wifi does work."
    Thank you to 'Superuser' 'Plemans' for the answer. :smileyhappy:
