Khatsalano
Jun 23, 2017Aspirant
Can I update R6400 running firmware: V1.0.1.6_1.0.4 directly to R6400-V1.0.1.24?
My first attempt to update the R6400 router firmware from V1.0.1.6_1.0.4 to R6400-V1.0.1.24 failed with the result: "Incorrect version." Is R6400-V1.0.1.24 a cumulative update containing all previou...
- Jun 24, 2017
After the firmware update failed last night, I wanted to make sure that it was ok to install v1.0.1.24 on top of 1.0.1.6. With that assurance, I repeated the update procedure today and it worked.
Thanks.
michaelkenward
Jun 24, 2017Guru - Experienced User
Looking at the links I provided, there is a V1.0.1.6, without the extra bit, for the R6400.
If you can see that information in the browser, you can tell the router to update itself. (Details in the manual on the page I linked to.) It should offer you the latest firmware that your current firmware will accept.
With luck you can skip the last five versions.
Khatsalano
Jun 24, 2017Aspirant
Thanks.
