Gdog1
Nov 29, 2021Follower
Can I use more than one EX6120 with my network?
I have an R6400 router with one EX6120 extender. It works well, but I could use another extender. Can I use two EX6120s without causing a problem?
michaelkenward
Nov 30, 2021Guru - Experienced User
No reason why it shouldn't work. But you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
