atomarchio
Dec 11, 2015Tutor
Can I use N750 router as access point or range extender?
I've recently replaced an N750 router I was using in my home. However, I would like to use the N750 as an access point or range extender to improve my wireless signal in a specific room of my home w...
- Dec 11, 2015
I've got it working. Thanks.
Good thing you explained to NOT FOLLOW their instructions in the manual. That really screwed me up for a while.
Suprised at how poorly it was written.
Thanks again!
atomarchio
Dec 11, 2015Tutor
Everything is down now. Do I change settings on primary r7000 router or on the n750 that I want to use as either bridge or access point?
And do I want bridge mode or access point?
- Retired_MemberDec 11, 2015
ALL changes are done in the N750 setup. Also as already stated you setup as AP and NEED a cable connection.
If you jacked around with R7000 and cannot use it which it sounds like you may have done. PUSH reset until Power Led flashes which will revert it to a router again with factory settings.
Page 113 shows how to setup as a Bridge, bridge will offer a wired connection But will not expand WIFI signal
