atomarchio
Dec 11, 2015Tutor
Can I use N750 router as access point or range extender?
I've recently replaced an N750 router I was using in my home. However, I would like to use the N750 as an access point or range extender to improve my wireless signal in a specific room of my home w...
- Dec 11, 2015
I've got it working. Thanks.
Good thing you explained to NOT FOLLOW their instructions in the manual. That really screwed me up for a while.
Suprised at how poorly it was written.
Thanks again!
Retired_Member
Dec 11, 2015Power cycle....wait for it to reboot..... several minutes...........remove ALL other cables except power... push/hold about 10 seconds for power to flash
atomarchio
Dec 11, 2015Tutor
I have this working again. Thanks.
How can I access the settings of the N750 and not the primary router? I've read the instructions but that only gets me to the primary router (N7000) screen.
Please help. Thanks.
- TheEtherDec 11, 2015Guru
Connect to the N750 by its IP address. If you don't know its IP address, then you can find it on the R7000's list of attached devices.
- atomarchioDec 11, 2015Tutor
I did a factory reset on the N750 and connected to my network via the yellow internet port.
It's showing up on my router list but when I enter the IP in my browser bar it will not connect.
Is there another way to connect? Please help. Thanks.
- Retired_MemberDec 11, 2015
When doing a reset it went back to router mode. Download and read through the manual.
N750 is not a model number, so you might want to use the model number going forward.
