atomarchio
Dec 11, 2015Tutor
Can I use N750 router as access point or range extender?
I've recently replaced an N750 router I was using in my home. However, I would like to use the N750 as an access point or range extender to improve my wireless signal in a specific room of my home w...
- Dec 11, 2015
I've got it working. Thanks.
Good thing you explained to NOT FOLLOW their instructions in the manual. That really screwed me up for a while.
Suprised at how poorly it was written.
Thanks again!
TheEther
Dec 11, 2015Guru
It can be used as a wired access point. The manual starting from page 111 has the instructions for setting it up.
It cannot be used as a wireless range extender.
michaelkenward
Dec 12, 2015Guru - Experienced User
TheEther wrote:It can be used as a wired access point.
Does that mean Powerline wired as well as cable wired?
In other words, rather than running a LAN cable from modem to access point, would a pair of Powerline plugs achieve the same result with this modem?
While it would normally be better to have a directly wired connection, there can be times when running a wire around the place isn't that easy. Using the mains circuit and Powerline plugs could be an alternative strategy.
I ask for the benefit of anyone else who may turn up with similar questions about turning an old modem into an "extender".
