atomarchio
Dec 11, 2015Tutor
Can I use N750 router as access point or range extender?
I've recently replaced an N750 router I was using in my home. However, I would like to use the N750 as an access point or range extender to improve my wireless signal in a specific room of my home w...
- Dec 11, 2015
I've got it working. Thanks.
Good thing you explained to NOT FOLLOW their instructions in the manual. That really screwed me up for a while.
Suprised at how poorly it was written.
Thanks again!
TheEther
Dec 12, 2015Guru
Yes, Powerline is acceptable. It's not as consistent and reliable as Ethernet, but it will still avoid the half duplex problem.
michaelkenward
Dec 12, 2015Guru - Experienced User
TheEther wrote:
It's not as consistent and reliable as Ethernet...
Indeed, which is what I said, but I have used Powerline to successfully "bridge" between buildings that are on the same mains circuit. An Ethernet wire would be a nightmare. In this case, the user seems to be able to go the LAN route. Much better.
