Gregory_M
Jul 24, 2021Aspirant
Can I use two AC750 WiFi range extenders at once?
I have two AC750 WiFi Range Extenders and I would like to use both of them in different areas but I could not log in to set up the second one. Is it possible to use two at once and if so how do I...
Jul 24, 2021Guru - Experienced User
start with factory resetting the one you can't setup.
Push and hold reset for 7-15 seconds while powered on.
then power off the working one.
Then power on the one you need to setup.
use the installation assistant to install it.
Once installed, power the working one on.
- Gregory_MJul 24, 2021Aspirant
I was having trouble logging in on line to do the set up. I put in my email address and my password and it just sat there and would go no further.
