swaasje
Oct 16, 2020Aspirant
Can I use wifi router as a switch?
Can i disable the wifi and the DHCP table to use the router as a switch?
- Oct 18, 2020
> All done. [...]
_What_, exactly?
> I am worried that the status says DHCP ON
I'd guess that that's accurate only if the router is acting as a
router, not when it's configured as a WAP.> The Genie offered to use the Netgear as an AP
After a settings reset, if it sees a private address on its
WAN/Internet interface, then it might draw the correct conclusion
automatically.> I kept SSID broadcast on recommendation. [...]
That doesn't matter much if the radio is disabled. The point was
that "Enable SSID Broadcast" and "Enable Wireless Router Radio" do
different things.
> So DHCP organises the different ports? [...]I'd say "connected devices", not "ports".
https://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol
> I had problems in the past with WAP acting like a router and
> distributing weird IP addresses on our network.Generally, you want one DHCP server per LAN. Multiple uncoordinated
DHCP servers can cause many problems. Which is why the one-step WAP
mode option disables the DHCP server. (And, why you would need to
disable it explictitly, if you don't use the one-step WAP mode option.)So, it works as expected now? (What could go wrong?)
Possibly interesting:
swaasje
Oct 18, 2020Aspirant
I surely know my knowledge limits! That's why i'm on this community. Thanks for your light.
Then unchecked the box "Enable Wireless Router Radio" which i don't want.
I kept SSID broadcast on recommendation. Thank you.
Wireless light is now OFF
You say " No, you really _do_ want that. Configuring the WNR2000v5 as a WAP
stops the router functions of the WNR2000v5 (such as the DHCP server),
leaving only the network-switch and wireless-network functions. You do
want the network-switch functions, right?"
So DHCP organises the different ports? essential to a switch?
I had problems in the past with WAP acting like a router and distributing weird IP addresses on our network.
antinode
Oct 18, 2020Guru
> All done. [...]
_What_, exactly?
automatically.
different things.
