Mike37
Jun 25, 2016Aspirant
Can not access the www.routerlogin.net or www.routerlogin.com or IP Address for my WNDR3800 Router
Hello I trying to access my Wifi on the wndr3800 Router , i dont know the passwords, i looked on line and none of web sites to access this Router are working www.routerlogin.net or www.routerlogin.c...
- Jul 05, 2016
TheEther
Jun 25, 2016Guru
www.routerlogin.net and www.routerlogin.com are used to log into your router's management portal. You must, of course, be connected to your router's network (through Ethernet or Wi-Fi) in order to log into the router. If you don't know your router's Wi-Fi password, then presumably you are not connected via Wi-Fi. Do you have a computer with an Ethernet?
The WNDR3800 uses a default IP address of 192.168.1.1. 192.108.01 is not a properly formatted IP address. Netgear has an article that details how to find the IP address of your router.
- Mike37Jul 05, 2016Aspirant
