ROBBO1972
Dec 26, 2017Initiate
Can not upload chk file
Hello Can any one help ? Having trouble latest upgrading firmware, will not let me upload because it is a chk file, tried to do it on web page where it says check, but no yes button to start upgrad...
- Dec 26, 2017
OK fixed problem needed to unzip file first
ROBBO1972
michaelkenward
Dec 27, 2017Guru - Experienced User
Which firmware is this?
Netgear has done a rapid update for the D6400. Just days after upgrading mine I found a new version, V1.0.0.70.
66 landed on 14 December, 70 arrived 10 days later!
66 must have been a dud.
PS Thanks for passing on the solution. This is a common issue, so your Solved answer might help someone in the same boat who turns up here seeking help.
