micselafey's avatar
micselafey
Can only access router through IE
How come I can only access routerlogin.net from internet explorer? I cannot access it through any other browser. If Big Daddy MS is phasing out IE then eventually I won't be able to access my router I assume.
Hope someone can offer a solution.
Thanks, Mike
  • > [...] I cannot access it through any other browser. [...]
       Which browsers does "any other browser" include?
       "cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       Have you tried using the LAN IP address of the router, instead of
    "routerlogin.net"  Or, for a cable-TV-type gizmo, "192.168.100.1"?
       Which kind of "not working" is this?  Actual error message?
       One possibility with modern browsers is the use of DNS-over HTTPS.
    See, for example:
          https://support.mozilla.org/en-US/kb/firefox-dns-over-https
          Some individuals and organizations rely on DNS to block malware,
          enable parental controls, or filter your browser's access to
          websites. When enabled, DoH bypasses your local DNS resolver and
          defeats these special policies.
    • micselafey's avatar
      micselafey
      Sorry for the lack of info. Not an IT person so a simple solution is needed. I can only access through IE and I've tried Chrome, Edge & Firefox. Same message (or similar) on each on:
      "This page isn’t working
      routerlogin.net sent an invalid response."
      But no problems at all through IE.
      Thanks, Mike
      • michaelkenward's avatar
        michaelkenward
        That still works here. But browser makers are working hard to make their software "more secure", which can put obstacles in the way of users.
        The solution is with the browse rather than the router. There may be something you can tweak in the browser.
        One way around this is to track down the local IP address of your router. Unless something is abnormal this is usually 192.168.0.1 or 192.168.1.1
        Put that into your browsers and see what you get.
        If you cannot login to your router | Answer | NETGEAR Support
