beverly0807's avatar
beverly0807
can open Netgear Genie
when I try to login into my account using Netgear Genie, I get a message saying my router is not found or supported.  HELP, I just need to see if software upgrade is available. Using El Capitan OS 10...
  • beverly0807's avatar
    beverly0807
    Jan 22, 2016
    Hi again Elaine, well guess what....I was finally able to log in....I went to the network support tab first and entered my email address and password.  Once I was logged in, I was able to go to the router settings tab and do what I wanted to do.  It never worked this way before....I was always able to log in through router settings first, but no matter...I'm in now and thanks very much again for your help!
