SarwarFX
Nov 22, 2022Aspirant
Can somebody explain this?
Please see the attached image for better understanding
1. what modem/gateway do you have?
2. what router do you have?
3. what firmware is on it?
- SarwarFXAspirantI have updated the router's firmware. But it still the same. TV doesn't stream.
SarwarFX wrote:
I have updated the router's firmware. But it still the same. TV doesn't stream.I still have no idea what is happening at your end.
A picture may be worth a thousand words, but "no words" is worth nothing.
You will see from other conversations that this place is mostly written down stuff. By all means add pictures to clarify your story, but start with a description of your issues.
Can you explain what you are doing and where things go wrong?
What TV? Streaming from what and to what?
And what Netgear equipment do you own?
Then there are the questions from plemans. They may be the same old same old, but they are there for a reason.
