poofybunhead
Oct 14, 2016Aspirant
can someone just confirm this should work to display the default USB storage icon only
My USB storage attached to my R6050 displays 2 icons on my win7 box. one is the default"readyshare" and the other is "WD" which I created. Since I just want one only to display I should be able to u...
- Oct 24, 2016
Many thanks to Dexter for the response to my question, to follow up then....
Due to a lack of response before Dexters reply I just unplugged the attached storage, reset the router to factory settings and reattached the storage. While I did end up with 2 icons in my win7 box(R6050 & ReadyShare) I just reset my back up software to write to the ReadyShare. Confirmed that the backup software was functioning ok.
again my thanks to Dexter
DexterJB
Oct 23, 2016NETGEAR Moderator
Hi poofybunhead,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- poofybunheadOct 24, 2016Aspirant
- DexterJBOct 25, 2016NETGEAR Moderator
