poofybunhead's avatar
poofybunhead
can someone just confirm this should work to display the default USB storage icon only
My USB storage attached to my R6050 displays 2 icons on my win7 box.  one is the default"readyshare" and the other is "WD" which I created. Since I just want one only to display I should be able to u...
  • poofybunhead's avatar
    poofybunhead
    Oct 24, 2016
    Many thanks to Dexter for the response to my question, to follow up then....
    Due to a lack of response before Dexters reply I just unplugged the attached storage, reset the router to factory settings and reattached the storage.   While I did end up with 2 icons in my win7 box(R6050 & ReadyShare) I just reset my back up software to write to the ReadyShare.  Confirmed that the backup software was functioning ok.
    again my thanks to Dexter
