gamathers
Nov 20, 2020Aspirant
Can the wifi be shut down and just use hardwired?
I have laid hardwire to all locations I use ethernet. Is there a way to turn off the wifi transmission?
- Nov 21, 2020
> [...] I wouldn't tell the other person that they just can't handle it.
> [...]I don't recall saying anything like that. But it's clear that you
haven't "handled it" so far.> [...] I can tell when a Manual doesn't match reality. [...]
When trying to match "a Manual" with "reality", it helps to look at
the right part of reality. Reality is a big place, with many parts.
Can you tell when you're trying to match two different things?> The picture in the manual does not correspond to what I am seeing on
> my screen. [...]Exactly. That's because you're looking at the wrong page on your
screen. Read it again, more carefully:
> The following two action chains are different:
> What you did:
> ADVANCED > Setup > Wireless Setup
> What the User Manual says:
> ADVANCED > Advanced Setup > Wireless Settings(The Manual actually says "Advanced > Advanced Setup > Wireless
Settings", but "ADVANCED" is correct.)> However on the Advanced Wireless screen [...]
_Which_ "the Advanced Wireless screen"? See above (again).
> I did include a picture of what I am looking at. [...]
Yes. That's how I could tell that you were on the wrong page. (And
exactly which wrong page you were on.)
> [...] I can try an update of the software, although I doubt that it
> will bring back that option.I agree. It's a user error, not a firmware problem. (Unless you
count poor user-interface design as a firmware problem, and I would not
expect an update to solve that.)
antinode
Nov 20, 2020Guru
> [...] Is there a way to turn off the wifi transmission?
Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Advanced
Wireless Settings" and "Enable Wireless Router Radio".
- gamathersNov 20, 2020Aspirant
Perhaps there is someone that is not a total insufferable Jerk as this guy is. I looked at the manual and the option displayed in the PDF manual is not available on my display. Perhaps I just need to purchase a switch.
- antinodeNov 20, 2020Guru
> guy is. [...]It's possible, but you still might need to read more carefully than
your "I looked at the manual".The following two action chains are different:
What you did:
ADVANCED > Advanced Setup > Wireless SettingsI'll admit that "RTFM" does not always work well for people who don't
read well.You have my permission to complain to Netgear about the way they
organized these headings.
> [...] Perhaps I just need to purchase a switch.I'll bite. To do what, exactly?
> I'll bite. To do what, exactly?Oh. I get it. You want to replace a router (WNDR3400v3) with a
_network_ switch? "router" and "switch" are spelled differently for a
reason. Generally, if you have typical residential Internet service,
you'd need a (NAT) router in order to connect multiple client devices to
the Internet. A network switch lacks the requisite NAT functionality.
