OldBob
Jul 04, 2019Luminary
can wndr3300 dual band with 150 mbps speed from Cox
My Netgear 3300 WMDR dual band seems to work fine but never get speeds as claimed by Cox. I have DOCSIS modem. They supposedly sending speeds up to 100BPS and I test and only get 25-45. Is this ...
- Jul 04, 2019
> My Netgear 3300 WMDR [...]
Assuming that that's actually a WNDR3300[v1], then you have a nice
antique.> [...] I have DOCSIS modem. [...]
My car has four wheels. Has your modem a maker and model number?
> [...] Is this older router capable of sending these new speeds.
If that's a question ("?"), then probably not.
> [...] I test and only get 25-45.
"test" how?
> [...] they upped my speed to 150 MBPS and to reset the modem to get.
> I did so and no difference ..any suggestions?Get a router designed after 2007? Like time, technology marches on.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the WNDR3300 Setup Manual. Read. Look
for "Interface Specifications" (toward the end):LAN: 10BASE-T or 100BASE-Tx, RJ-45
WAN: 10BASE-T or 100BASE-Tx, RJ-45With 100Mb/s Ethernet ports, you definitely won't get 150Mb/s through
that router.
antinode
Jul 04, 2019Guru
antique.
"test" how?
that router.
- OldBobJul 04, 2019Luminary
Thank you for your reply. I cannot or do not know how to read the various links you provided but the last one to check my spect for my router do indeed say the 100 so I guess thats all I will get. When I connect the laptop directly to the router I get 98 mbps ..is it usual to get only half that coming thru the router? I dont do heavy gaming but do have grandchildren who visit and want to connect.if I bite the bullet what model would you reccommend under like $200 that will take this new speed of 100 from Cox.
- antinodeJul 04, 2019Guru
> [...] When I connect the laptop directly to the router I get 98 mbps
> .. [...]I assume that you meant "directly to the [unspecified] modem".
> [...] is it usual to get only half that coming thru the router? [...]
> "test" how?
Still wondering.
When that router was designed, 50Mb/s might have been considered
perky.> [...] what model would you reccommend under like $200 [...]
I don't recommend equipment here, but almost anything with the word
"gigabit" (_not_ "Fast") or the number "1000" near "Ethernet" or "LAN"
on the box would have a factor of ten advantage over your current
antique. A quick look at bestbuy.com suggests that almost anything over
about $70 would do. The letters "AC" would probably mean a newer
generation of wireless, too. (Also probably hard to avoid above about
$70.)
