dbro
Feb 07, 2017Aspirant
Can you have two wireless networks if you have two modems but only one computer?
I had time-warner install a cable modem and bought an AC1700-6400 wireless router. The tw tech could not get the wifi to work but was in a hurry so told me to call support. I asked him if I could hav...
- Feb 07, 2017
dbro wrote:
I had time-warner install a cable modem and bought an AC1700-6400 wireless router. The tw tech could not get the wifi to work but was in a hurry so told me to call support. I asked him if I could have two wireless connections at the same time, he said yes. I have not shut down my ATT Uverse because it is connected with wireless to my TVs and Rokus. The account is good until 15 Feb. I was going to use the same name and password as my old wireless connection so that I wouldn't have to change everything in the house thats wireless. Is the Time-Warner man correct that I can have two wireless connections in the same house? I am using one computer for the wired network that is connected to TW. It does not make any sense to me. I figured I would have to shut down my ATT Uverse and wireless connection before the Netgear router will make a wireless network. Am I correct?
You cannot run a single seamless wireless network with two different ISPs unless you use a dual-WAN-capable router or load balancer. With your current equipment you can run two separate wireless networks. Switching between will not be seamless.
TheEther
Feb 07, 2017Guru
- William10aFeb 07, 2017Master
Here is the link for D-links load balance device for up to four modems to a single lan feed https://www.youtube.com/watch?v=YDUfP8a5zNY.
- dbroFeb 08, 2017Aspirant
Thanks for your help. I can't seem to get anyone that I have spent money with to give me the correct answer. Very frustrating.
