uptownvideo
Jan 24, 2022Apprentice
Cannot access router management
I have not been able to access the router management page using a computer or mobile app since lately. I have tried chrome, safarit, firefox and the Genie app. I even tried my laptop hard wired eth...
uptownvideo
Yes the model is C6300. I tried that router IP and routerlogin.net in different web browsers. It has always has been 192.168.0.1.
Jan 24, 2022Guru - Experienced User
did you try the modem side? 192.168.100.1
- uptownvideoJan 24, 2022Apprentice
yes I tried that also.
"Safari Can't Connect to the Server"
- plemansJan 24, 2022Guru - Experienced User
Have you tried a factory reset?
Push and hold reset for 7-15 seconds while powered on?
I have not done a factory reset as that is probably too drastic to do now. Will that erase all configs such as SSIDs and passwords?
