PEY's avatar
PEY
Cannot access some sites with last 2 Netgear routers I have installed using default settings with wi
I cannot access the site rail-logic.com with any of my devices over wired or wireless connection using the Nighthawk X10 or X6 router.
All settings are factory default.
If I bypass the router and connect directly to the cable modem, I can access the site with no problem.
If I use my wireless hot spot on my cell phone, I can also access the site with all my devices.
I read older post and tried changing the MTU setting with no improvement.
Appreciate any help, as the problem appears to be with the Netgear routers, and so far, I cannot find any settings to change that will allow me to access the site. I am impressed with the speed and the range of these routers.
My router is not in the list, so showing here. Nighthawk X10 AD7200 Smart WiFi Router.
  • PEY's avatar
    PEY
    Nov 10, 2016
    Changing my MAC address fixed the problem. Thanks to everyone who responded.
  •  Did you power off your modem for about ten minutes before plugging your new router into the modem? (gives time for your ISP to age out the old MAC address). You can also try cloning your laptop MAC address onto the routerand retry..
    • PEY's avatar
      PEY
